| | 1/18 scale Tervamaki Engineering JT-9T autogyro | |
| Auteur | Message |
Nick_Karatzides Officer cadet
Nombre de messages: 100 Age: 36 Localisation: Greece Date d'inscription: 15/06/2009 Points: 312
 | Sujet: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:05 | |
| 1/18 scale Tervamaki Engineering JT-9T autogyro scratchbuild Having tried my (suicidal) virgin 40 minutes flight experience with a friend's homemade autogyro during my summer holidays with him on flight controls and me on the passenger's backseat, I can surely say that you really feel like a bird, sensing even the slightest airwave or gravity accelerating change straight in your floating stomach. As soon as I safely stepped on solid ground again and returned back home in one piece, I felt the iresistable temptation to try a 1/18 scale autogyro scratchbuild. The following article is to describe step by step the 1/18 scale Jukka Tervamäki Engineering JT-9T autogyro, designed by Mr. Jukka Tervamäki and currently flying by ultralight aviators around the world keeping the Mad Max II GyroCaptain's (aka Road Warrior) spirit alive! In the photo below, Mr. Jukka Tervamäki, with his latest (at that time) creation of the JT-5, which was a predecessor of JT-9, which I'll try to represent in scale.  The basic JT-9 autogyro concept is about a tractor gyro design with good aesthetics and performance with fairly low power. A 1.7 m diameter 2-blades propeller is powered by HKS 700 or Hexadyne Aviation P60 diesel engines, both delivering about of 65 hp at 2400 rpm. The fuselage of the JT-9 is of normal steel tube construction covered with dacron fabric. On the other hand, the JT-9B model is equipped with an electric motor instead of a diesel engine, with only difference the 3-blades propeller and wider front cover to house the battery packs onto both sides of the fuselage. The model I'll try to build in 1/18 scale, is the two-seat trainer (as for the "T") JT-9T model, equiped with diesel engine & 2-blades propeller made by carbon fibers. Having the basic blueprint line diagrams in hand, it was easy to convert them into 1/18 scale with a photocopier and I began the scale model building, starting from zero using 0.25mm styrene card and plastic sprue. To make the construction look more interesting, I decide to build the model in a way that airframe should look like cutaway side opened and let cockpit detail be easily observed. In the following pictures, the real (one-seat) Alex's autogyro JT-9, during the successive stages of building.
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:07 | |
| CHAPTER I - Basic airframe skeleton construction   Following the 1/18 scale printed diagrams and using just a sharp blade and ZAP superglue, it took about 60 minutes to build the basic airframe skeleton. The tiny gaps between the skeleton connections, were filled with Humbrol modeling putty, applied with an old brush. In order to make the putty liquid and let it spread naturally and fill the tiny gaps, I mixed it with laquer thinner. Because the laquer thinner is volatile, the liquid putty mixture took about 45 minutes to get fully dry and be safe to sand - carefully ofcourse. If you follow this method, be sure that you mix the laquer thinner and the modeling putty into a metal or glass plate / canister, because the most plastic materials cannot stand it and melt. For this reason, keep in mind to use just the essential laquer thinner quantity, in order to remain the mixture in liquid form, as it is presented at the following pictures. About 45 minutes after laquer thinner and Humbrol putty liquid mixture applied with brush on the skeleton to fill the tiny gaps between the connections, it looked to be fully dry and safe to sand it. As soon as that was done, the skeleton was hanged by a string and airbrushed with enamel mat white color as a base coat. Cockpit floor, wheels etc made while waiting the putty to dry, were also spayed with base coat.
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:09 | |
| CHAPTER II - Diesel engine building & painting Setting as a task to build the model in a way that airframe look like cutaway side opened with cockpit and engine bay details visible, I should also leave the engine's cover opened. that offcourse means that a diesel engine building from scratch is something I couldn't easily avoid. Using plastic card, sprue, metal wire and unidentified parts found in the sparebox, here is my effort to build a realistic 1/18 scale engine. After connecting with superglue the main elements, the electric cables and oil or diesel lines etc on engine's shape, I airbrushed it with enamel mat white color as a base coat, using high air pressure and spraying from distance to develop a pore surface and help silver & aluminum paint establish easier on plastic or metal engine's parts. As soon as the enamel mat white color seemed dry enough, a mixture of silver and aluminum paint sprayed on the engine and let about 24hrs to dry before trying to wash it with darker colors. As I personally believe that following simple techniques and sometimes unconventional methods, result in superior effects, I usually do not use enamel or acrylic paint to wash, because I feel risky when applying the paint mixture and let it run. I prefer an easier technique that can be undone if the results are poor - that makes it the perfect technique. I use hard chalk pastels to wash (NOT oil pastels). The hard chalk pastels, look like a teacher would use on the blackboard in school. Do not use the soft oil pastels that artist use to draw on paper. The hard chalk pastels are easy to find in a variety of colors into your local art store or maybe Wal-Mart if in US or ASDA if in UK. To do the wash, I use an X-acto knife, a small metal or plastic container, an old brush, dish washing soap and a bit of water. Begin by scraping some chalk powder from the side of the chalk pastel stick, carefully put this chalk powder into the small container and add a tiny amount of water and stir. It is important to add a tiny amount of water in order to make the mixture look like mud - not like soup! For this reason, I use a syringe to add just few drops on the hard chalk pastel powder and I stir using the old brush. Because the chalk powder doesn't mix well with the water, a drop of dish washing soap is needed to break the surface tension of the water and also acts as a "glue" to help the chalk powder stick to the model. Once the chalk is fully dissolved into the water/soap mixture it is time to "paint" this mixture onto the model's engine. "Painting" the mixture is simple - just apply it anywhere it is needed to darken recessed detail. The mixture can be applied carelessly, because any mistakes can be completely removed and redone. Once the chalk wash dried, I rubbed off the high spots with a slightly damp dry (not wet) Q-Tip cotton swab (Kleenex papers can be also used) and I wiped the dark color from the areas should be light & shinny. The high spots were cleaned to the SNJ bare metal finish and the low spots were left black. I did the chalk wash on the engine in under 30 minutes which makes it a very quick and effective technique. You can also read about this into Steve Bamford's article, by clicking HERE. Some of the wash mixture is re-applied and the wash being wiped completely out of the narrow points. If you follow this method, it is adviced to not rinse out the wash container till you are finished this job. You will probably be touching up certain spots a few times, so it helps if you're not mixing up a new chalk mixture each time because you kept cleaning out your container of the chalk wash mixture. As soon as I paint the electric cables, the oil or diesel lines etc, I repeated the the wash process with lighter colors where needed. Using micro cotton batons found into cosmetic shop for less than 1£, I applied some red, orange, purple & brown chalk pastel powder on the engine's chrome excaust, to make it look overheated. I repeated the weathering process until it satisfied me and finally I sprayed a clear coat to seal the chalk powder on the engine.
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:10 | |
| Some pictures of my secret hideout / hobby room while scratchbuilding the 1/18 scale JT-9T autogyro model. Click on the first image to enlarge hi-res 180 degrees picture.
hooz Flying officer
Nombre de messages: 3270 Age: 33 Localisation: rozay en brie Date d'inscription: 19/08/2008 Points: 3694
Infos Fighters Echelle favorite: 1/48 =>: FIGHTERS Group Montages en cours / Mon stock:
   (3/12)
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:18 | |
Hervé Squadron Leader
 Nombre de messages: 5900 Age: 48 Localisation: PIERREGOT 80000 CH'PICARDIE Ma photo:  Date d'inscription: 18/11/2007 Points: 3927
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:26 | |
| Bonsoir; Idem pour mon Anglais mais les photos parles d'elles même. Serais ce le fils de Madman?That is the question. En tout cas un montage didactactique et à suivre. Bonne continuation. Hervé. |
Invité Invité
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:32 | |
| houla la encore un pro!  |
fourneau Squadron Leader
 Nombre de messages: 5472 Age: 51 Localisation: 59 nord (douai) Ma photo:  Date d'inscription: 11/11/2007 Points: 4927
Infos Fighters Echelle favorite: 1/72 =>: FIGHTERS group Montages en cours / Mon stock:
   (2/6)
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:50 | |
G. Chapuis Co-Admin
 Nombre de messages: 11032 Age: 58 Localisation: Chaumont Eyzin-Pinet dans l'Isère Date d'inscription: 05/03/2005 Points: 4768
Infos Fighters Echelle favorite: Toutes =>: FIGHTERS Group Montages en cours / Mon stock:
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Mer 12 Aoû 2009 - 19:54 | |
| _________________ Visitez mon Blog et n'hésitez pas à poster des com http://autoavionpassion.centerblog.net/ On a tous le sang de la même couleurProchain montage :    |
Tom's Flying officer
 Nombre de messages: 3800 Age: 28 Localisation: Troyes Date d'inscription: 16/07/2007 Points: 2197
Infos Fighters Echelle favorite: 1/144 =>: FIGHTERS Group Montages en cours / Mon stock:
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Jeu 13 Aoû 2009 - 11:50 | |
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Lun 31 Aoû 2009 - 4:39 | |
| CHAPTER III – Instrument panel & cockpit construction The original Tervamaki Engineering JT-9T autogyro instrument panel is not what you would call as "glass cockpit". Actually it does only have just the basic instruments in cockpit to provide the pilot with information about the flight situation, such as height, speed and attitude. Since the JT-8T autogyro is not designed to fly in conditions of poor visibility or night, the main information is available from visual reference outside the aircraft. Of course, many pilots who are lucky enough to own an autogyro, they might add more sophisticated equipment such as CFT screens, HSI - Horizontal Situation Indicator to follow VOR signals, GPS screens, VHF/UHF radio, replace the heading indicator by a GPS-driven computer with wind and glide data etc. The basic instrument panel is consist by: - An altimeter indicator,
- an ADI - AttituDe Indicator,
- an ASI - Air Speed Indicator,
- a VSI - Vertical Speed Indicator,
- a fuel quantity indicator,
- an engine RPM tachometer,
- an analog clock and
- a magnetic compass.
I started by cutting the main panel shape in plastic and drilled the gauges positions. Using the Corel Photo Paint, I created a colored sketch of the instruments, copy & paste the image into a MS Word new file and print it on a simple A4 page. Meanwhile, I add some detail on the instrument panel, such as rivets made by streached sprue inserted in drilled out holes, knobs etc.
yazo974 Flying officer
 Nombre de messages: 1248 Age: 44 Localisation: saint-denis réunion Date d'inscription: 02/02/2008 Points: 3087
Infos Fighters Echelle favorite: 1/48 =>: Montages en cours / Mon stock:
   (2/12)
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Lun 31 Aoû 2009 - 6:03 | |
| Je ne savais pas qu'ils maquettaient dans la station MIR.  |
kitou Officer cadet
 Nombre de messages: 203 Age: 51 Localisation: port-vendres 66660 Date d'inscription: 19/02/2009 Points: 189
Infos Fighters Echelle favorite: 1/32 =>: Montages en cours / Mon stock:
   (3/10)
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Lun 31 Aoû 2009 - 6:26 | |
Xanathos Squadron Leader
 Nombre de messages: 7459 Age: 41 Localisation: Velaux Ma photo:  Date d'inscription: 09/11/2006 Points: 4385
Infos Fighters Echelle favorite: 1/72 =>: FIGHTERS Group Montages en cours / Mon stock:
   (5/250)
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Lun 31 Aoû 2009 - 6:56 | |
| Magnificent lesson of scratch! Bravo, in more it allows us to discover a new machine.
Ciao bye Xanathos |
RCR Officer cadet
 Nombre de messages: 444 Age: 53 Localisation: LE PLESSIS ROBINSON Date d'inscription: 04/07/2008 Points: 262
 | Sujet: Re: 1/18 scale Tervamaki Engineering JT-9T autogyro Lun 31 Aoû 2009 - 8:54 | |
| BRAVO, très beau début de prestation.
Merci à toi et sois le bienvenu, nouvel ami grec. |
