[A&A Models] 1/72 - Dassault Mirage IVA (miva)
+22
GRANDFOC
ATAR93
LaurentJAG
jagouille
Zorg
dark83000
starfighter
Stéphane B
LowLow
Lee Coll
26 participants
Page 4 sur 4
Page 4 sur 4 • 1, 2, 3, 4
Re: [A&A Models] 1/72 - Dassault Mirage IVA (miva)
Très beau travail et doc au top.
Nombre de messages : 4128
Thanks to all of the supportive modelers who have maintained an interest in this extended project.
The printed radome as it came off the printer included a drain hole to avoid leaving liquid resin in a concave part when the printing process was being finished. This was filled during subsequent stages and sanded then polished out to match the surrounding surface. The transition areas to each side of the radome would be built up with epoxy putty, but you see it here mounted in it's position with Bare-Metal foil on the underside of the fuselage to avoid the putty from sticking to this area. The model had yet to be primed overall, so you see a lot of the ugly parts that are the result of panel line filling.
You now see that the epoxy putty has been applied to fair in the sides of the radome base, with the idea to get an approximate shape that will later be refined with sanding and filing.
The shaping of the areas surrounding the radome are starting to improve the appearance, even though there are a decent amount of blemishes yet to be smoothed out. It has taken about 4 iterations of sanding, priming, repeat to achieve this result. Doing it a few more times should fix everything.
As we approach a commitment to the final installation, you can see that there are still a few small areas that need cleaning up. As mentioned previously, I intend to re-scribe the fuselage before final fitting of the radome.
The last image shows it going down fairly snug when a little pressure is applied.
Lee Coll- Nouveau Fighterien
- Nombre de messages : 28
Very very nice work
Nombre de messages : 80032
Oui jolie, mais moi et cette langue
RogSimu- Fighterien dynamique
Nombre de messages : 2018
Ma photo : Roger
Passe le sur GOOGLE TRAD... puis copier collé sur le forum! Et tout le monde aura la tradoc des textes de notre ami!RogSimu a écrit:Oui jolie, mais moi et cette langue
Ca le staf n'a pas le temps de le faire et une aide est toujours appréciée!
MESSAGE
METEOR Clerc-Scott
TEMPEST Deleuze - Vaissier
DB-7 FRROM
HE46 Chateauroux
Nombre de messages : 34655
Lee Collpifortyman a écrit:Passe le sur GOOGLE TRAD... puis copier collé sur le forum! Et tout le monde aura la tradoc des textes de notre ami!RogSimu a écrit:Oui jolie, mais moi et cette langue
Merci à tous les modélisateurs de soutien qui ont maintenu un intérêt pour ce projet étendu.
Le radôme imprimé tel qu'il sortait de l'imprimante comprenait un trou de drainage pour éviter de laisser de la résine liquide dans une partie concave lorsque le processus d'impression était terminé. Celui-ci a été rempli au cours des étapes suivantes et poncé puis poli pour correspondre à la surface environnante. Les zones de transition de chaque côté du radôme seraient construites avec du mastic époxy, mais vous le voyez ici monté dans sa position avec une feuille Bare-Metal sur la face inférieure du fuselage pour éviter que le mastic ne colle à cette zone. Le modèle n'avait pas encore été amorcé dans l'ensemble, vous voyez donc beaucoup de parties laides qui résultent du remplissage des lignes de panneaux.
Vous voyez maintenant que le mastic époxy a été appliqué sur les côtés de la base du radôme, avec l'idée d'obtenir une forme approximative qui sera ensuite affinée avec un ponçage et un limage.
La mise en forme des zones entourant le radôme commence à améliorer l'apparence, même s'il reste une quantité décente d'imperfections à lisser. Il a fallu environ 4 itérations de ponçage, d'apprêt, de répétition pour obtenir ce résultat. Le faire quelques fois de plus devrait tout arranger.
La dernière image montre qu'il descend assez bien lorsqu'une petite pression est appliquée.
En savoir plus sur ce texte sourceVous devez indiquer le texte source pour obtenir des informations supplémentaires
Envoyer des commentaires
Panneaux latéraux
Ma photo : Roger
Voilà mais personnellement si je mets un message sur un Forum anglais je vais le mettre dans la langue du dit Forum, je comprends pas vraiment cette politique, à quoi bon se casser le c¨l quand d'autres peuvent faire le travail, après si ça dérange personne je ne comprends pas ! mais bon pas ma vision des choses, on publie en connaissance des choses et du contexte selon l endroit ou l'on se trouve et on s'adapte pas l'inverse, ce qu'un membre peut faire le titulaire peut aussi le faire je pense, je travaille pas comme ça désolé
Ma photo : Roger
» [A&A Models] 1/72 - dassault Mirage IV A n°24 - Dernier Vol (miva)
» [Heller] Dassault Mirage IVA 1/48 (mIVa)
» [Heller] 1/48 - Dassault Mirage IVA (VINTAGE) (mIVa)
» [Heller] 1/125 - Dassault Mirage IV-A (mIVa) (VINTAGE)
» [WINGMAN MODELS (KINETIC)] 1/48 - Dassault Mirage 5F
Page 4 sur 4
